RE: Brison & cap 232
had a 260 27% with a satio 180 in it and it flew very well , the mtr was new on the fisrt flight , vertical was forever but slow, the mtr was set very rich though, battery pack ejected and the mtr will be reassembled in the am,both mtrs you mentioned will fly that plane , you need to watch the weight on the brison and prop it right,if you weight less than 15lbs it should be fine , over that and it will in my opion be on the doggy side, hope this helps, now what plane do I want to get next???craig
