RCU Forums - View Single Post - Hovering The Magic 3D
Old 11-19-2002 | 01:09 PM
flyboone's Avatar
flyboone
Default Hovering The Magic 3D
Practise. As anyone can tell you practise is the best solution. My magic has an OS 46fx. It hovered fine at first but was real twitchy and I had a hard time. I thought it was because I was just starting out and also that I had heard the .40 size planes were harder to hover than big stuff. After a lot of practise and moving the CG back so that when inverted it flys same as upright with no down or up needed, I can now hover for as long as I want. Tail touches are regular occurences when I'm at the field. It's a lot of fun. It's hard to say which is the culprit but when I moved the CG back to where it is now, I was able to back it down a whole lot better. Could be the CG, or could be the Practise. Who cares, I can do it now and that's what matters. Good luck
Jason
