RCU Forums - View Single Post - Hovering The Magic 3D
Old 11-21-2002 | 02:57 AM
hat
Default Re: Hovering The Magic 3D
Originally posted by T-Neirynck
Yes, i have a Modle Tech Magic 3D and i can do anything i want, BUT, i have trouble trying to get it to hover, it only holds for a few seconds and snaps. Is there Certin CG im supposed to be useing or what? ANY TIPS WILL HELP! It has a 53 Magnum with a 11-7 wooden prop, i also have a 12-4 for it but only used it once. Im useing a Airtronic's RD 6000 and i have mixing abilities but i do not know what to put in for mixing, or if they are even needed?
Hi,
I have a Magic set up similarly to yours==YS 53, 12-8 Scimitar prop==weighs 3lb. 15oz. Do not know where it balances- just added weight in the tail until it flew correctly and does most 3D well. However, I find that most magic flyers gloss over the assembly instructions and neglect to put in the required downthrust and right thrust which is necessary to prevent the model from toppling to the right and/or backwards during hover!
Like yourself, the radio is an Airtronics RD6000, and no mixing is
necessary.
