RCU Forums - View Single Post - U.S engines?
Thread: U.S engines?
Old 01-02-2006 | 10:58 PM
freebird1
Default RE: U.S engines?
I figured your weight at 14LBs. That will give you 28.5 oz per foot wing load. That should be OK. Much more than 14LBS total will be to much. I know you want a yes or no answer, but unless someone has had this combo all we can do is suggess. a brick will fly with enough power, but it is when the engine dies the trouble starts. 30 oz per sq foot is the max. Take your total sq feet which is 7.875' divide that into your total weight in OZ. If over 30 look for another engine.
Hope it helps
