 U.S engines? >
U.S engines?
U.S engines?
Old 12-31-2005 | 05:44 PM
Default U.S engines?
Are these engines any good. Do they have alot of power. Would the 42cc be alright to put in my h9 extra 260?
Old 12-31-2005 | 09:16 PM
Default RE: U.S engines?
They are good engines, but they are heavy. THey seem to take a while to break in, but no big deal. The power to weight is going to be alot lower than glow with this gaser. They are more of a cub type engine.
Old 12-31-2005 | 09:18 PM
Sorry, I think the 42 is lighter than the 41cc. Is it the new type or older. Goodluck!!!
Old 12-31-2005 | 11:57 PM
It ways 72oz is that to much for the 260?
Old 01-01-2006 | 12:22 AM
qweedqwag's Avatar
My Feedback: (18)
Put a ZDZ 40 in the 260 it is the perfect engine for this plane is is light. It's what I have in mine.
Mike.
Old 01-01-2006 | 02:14 AM
Sorry I dont have that much money right now or any time soon.
Old 01-01-2006 | 05:22 PM
what will your total weight be, and what is the wing area in sq inches. I would not put it on your extra if the load is any more than 30 oz.
Old 01-01-2006 | 08:40 PM
Rcpilot's Avatar
My Feedback: (78)
ORIGINAL: mikmaxx
If your tight on money--and you have the US 41--then put it on there and fly it.
It might not fly as well as if it had a little bit lighter engine on it. But, it will fly. It's not gonna be a 3D monster--but it'll fly.
Not everyone can afford a ZDZ or a DA. It's okay.
The US 41 will be fine. Put it on the plane and go fly it. It'll be fun.
Good luck.
Old 01-01-2006 | 08:58 PM
I can afford the supertigre 3250 will that engine be good? I deffinetly want a 3d monster. Also is 66oz to much because I could also put in a 4500
Old 01-02-2006 | 10:12 AM
Rcpilot's Avatar
My Feedback: (78)
While the ST engines appear to be cheap--you will soon find out that they are not so cheap.
First off--the carbs suck. It's a subject of much debate here on RCU. Guys like me have tried and tried to get the carbs to run right, but to no avail. Others claim to have no problems with the ST carbs. Maybe it's one of those deals where some guys get a decent carb, and others don't.
In any event, you'll most likely want to replace the carb--or risk crashing the plane during a deadstick landing.
Carbs vary in price. You can buy an OS carb for it--and that will set you back about $60. Or Perry makes some carbs that will work too. They are cheaper.
Another thing you need to consider is your fuel tank. Your going to need something in the neighborhood of a 24oz tank to get any flight time out of that engine. These big glow engines are thirsty. Can you afford to fly it? Can you afford all the glow fuel that it's gonna take to fly the plane as often as you'd like? With a 24oz tank--you won't even get 5 flights out of a gallon of glow fuel. Then it's back to the hobby store for another $15 gallon of fuel. How much do you want to fly? How much can you afford to fly?
Another tank issue:
24oz of fuel weighs quite a bit. If you stick the tank up in the front of the plane--your going to notice that weight during the flights. When you take off, the plane will be very nose heavy. And, as you fly around and burn fuel, the plane will become less nose heavy. This changes the pitch characteristics of the plane. You'll be taking up elevator trim out as the tank gets lower and lower. Personally, I don't like messing with trim tabs. I set my planes up to fly with all trims in the middle, and I dial them in to fly that way. Whacking around with your elevator trim because the tank is getitng low--is a pain in the *****.
So--now you want to think about putting that 24oz tank back on the CG. That way, it won't effect how the plane flies. With the tank on the CG--your plane will fly the same at the neginning of the flight as the end of the flight.
How you gonna pull fuel up to the engine when your tank is 12" or 15" behind the firewall? Glow engines don't have pumper carbs like gas engines do. Your going to need a Cline regulator. Those are $60. If you put the tank on the CG--you can't get around it. You will need a Cline regulator--or it won't run right. Not even close.
So--how much do you have invested in this ST engine now?
$180 for the engine
$60 for a new carb
$60 for a Cline
Your up to $300 again.
I'd buy a conversion gas engine before I'd spend $300 on a big glow engine.
Check this out:
http://www.rcuniverse.com/market/item.cfm?itemId=157207
Thats a 46cc gas engine for $300 and it's brand new. It'll fly your plane--NO PROBLEM
Check the classifieds here on RCU. Lots of 35-45cc gas engines in the $300 price range.
Old 01-02-2006 | 10:16 AM
pl check out mvvs45mg
happy 2006
Old 01-02-2006 | 11:28 AM
is 69 ozs to much thats all I whant to know?
Old 01-02-2006 | 07:27 PM
Are bcma engines any good?
Old 01-02-2006 | 10:58 PM
I figured your weight at 14LBs. That will give you 28.5 oz per foot wing load. That should be OK. Much more than 14LBS total will be to much. I know you want a yes or no answer, but unless someone has had this combo all we can do is suggess. a brick will fly with enough power, but it is when the engine dies the trouble starts. 30 oz per sq foot is the max. Take your total sq feet which is 7.875' divide that into your total weight in OZ. If over 30 look for another engine.
Hope it helps
Old 01-03-2006 | 08:40 PM
That is a very helpfull tip freebird thank you very much! I dont want the us engine any more but a supertigre 3250 which way around 47oz with 3.2 hp. Or I want a engine that ways 66 oz and produces 4.1 horse power which one would any of you suggest more?
Old 01-03-2006 | 09:08 PM
You may want to check the Mark (Moki) engines from Hobby People I have the 135 and it is a great engine. Don't know if they will fit your wants as far as cost, but they will give the power at the weight you are looking for.
