pushrod again lt 40
disconnect the push rod from the nose gear and servo,by hand move the rod, it should move freely,if not then redo or replace the rod,I use Sullivan Gold-N-Rods but try to install straight with the least amount of bends.If rod moves freely then check wheel for binding.
