RCU Forums - View Single Post - pushrod again lt 40
Old 11-21-2002 | 08:17 AM
$ircra$halot
Default pushrod again lt 40
Hi Terrell Flyer: I use cables on all my nose wheels, I have 10 planes. All but 1 are trike gear, and have had no trouble with ground handeling. Take off rolls are straight as an arrow flying off Astro turf that needs to be replaced. I do brace the outer sleeve about every 3" to reduce the flex problem. As for running a cable from the throttle, I can see where if you have a connection come loose, it could cause rx interference but again I've had no problems. I also use plastic clevises for The throttle unless the throttle arm is plastic like on my Saito. I check everything, every nut, bolt, and screw, about every third flight. Now when I build a gasser, I will not use a cable because of all the post I've read that state cables do cause rx interference, The instructions that come with the ign. even warn against useng metal for throttle. Always happy to help if I can. Garry
