I started using them on the advise of a long time modeler and have never had any problems. I do use the allen key that you can really snug down. I have seen signs of the EZ connector coming loose from the servo arm when I used the plastic keepers to secure the connector to the servo arm, especially on the linkage that is going to the steering nose wheel. When I switched to the metel permanent type keepers, no more coming loose!
