RE: Screw Lock Connectors
Bruce, you show the DuBro round connectors in your response. Great Planes sells the same thing but with a square configuration that you can actually get a wrench on and hold steady while tightening the socket head screw. Is the DuBro product superior in your opinion or is that simply the one you happened to show? If the quality is comparable, I like the square ones better--they are the ones I've been using for years.
Max
