RCU Forums - View Single Post - Third scale Tiger Moth
Old 01-04-2006 | 04:37 PM
Idigbo's Avatar
Idigbo
Default RE: Third scale Tiger Moth
Here are a few more. Span is 111", estimated final weight is to be around the 30lb mark, power is a Z62. All radio is hidden under the scale central control box. The fuel tank is the scale tank. All fittings are from brass sheet, apart from some high stress areas, ie wing spar attachmants etc, are stainless steel, the luggage locker over centre latches work, although the liner for the locker still needs to be made.
Ian.
ID:	381017   Click image for larger version
ID:	381018   Click image for larger version
ID:	381019   Click image for larger version
ID:	381020   Click image for larger version
