RE: Blade CX Problem
All I can tell you is this.... if you replaced the famous 1212 piece to the upper rotor assembly then you must be careful that the counter weight bar is in front of the leading edge of the blades. If it is reversed the heli will lift off and spin out of control within seconds...as I learned the hard way, not once but twice before checking a forum like this to see what was up.
