RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Blade CX Problem
Old 01-04-2006 | 05:30 PM
Default Blade CX Problem
Alright so I got the blade CX for christmas and just got replacement parts for the rotor blades.... Problem... When i try to lift off all the little guy wants to do is spin in a violent circle... Its almost like it is automatically trying to adjust the gyro speeds but it does it drastically causing the bcx to spin. Anyone have a similar problem or any suggestions how to fix it?
P.S. Ive tried many different adjustments but nothing has worked
Old 01-04-2006 | 06:32 PM
Default RE: Blade CX Problem
All I can tell you is this.... if you replaced the famous 1212 piece to the upper rotor assembly then you must be careful that the counter weight bar is in front of the leading edge of the blades. If it is reversed the heli will lift off and spin out of control within seconds...as I learned the hard way, not once but twice before checking a forum like this to see what was up.
