Turns either way
apward,
The electric starters are made to turn either way, according to which way you hook it up. Normally when you hook it up, it is made to turn counterclockwise, but if you need to, such as the case sometimes when using a starting belt, you cn change the direction by hooking it up the other way (reversing the polarity).
Tommy
