RCU Forums - View Single Post - NEW QUEST
Thread: NEW QUEST
Old 01-05-2006 | 07:17 PM
  #117
CRAPTECH
Default RE: NEW QUEST
I just order a Quest last night. I have been out of RC for about 12 years and a lot of things have changed. WOW have they. I bought a stick over thanksgiving and what little skills I had seen to be returning. I figured that the Quest would be the next step, I don't know whether I want to go back into pattern or just fly big planes. so the Quest looks like the best of all worlds for now.
I don't want to over power it, so I think I will go with a ST.90. I may not use a pipe, just have a Macs muffler run down the center of the bottom. In the past I have had very good luck with set up and have not had to use pumps, so I might try it again. I guess that I may have some minor GC issue. I will most likely put the elevator and rudder servos as far up front as I can get them.
I was just sitting here and trying to figure out what type of servos to get. Any suggestion on a modest selection. and will just one work for the elevator? MLC, what prop did you end up using?
thanks all for any help.. T green
