RE: AHHHH!!
is it the bolt that the engine mount bolts to or does it hold the engine to the engine mount. if it holds the mount to the chassis you could possibly cut the mount really close to the chassis. if its the one holding the engine to the mount you could cut the mount away from the engine. either way the mount would be destroyed but the engine would come off.
