RCU Forums - View Single Post - RX Antenna problem
Old 01-06-2006 | 03:18 PM
Rx79394
Default RE: RX Antenna problem
here this should work no need for soldering, all you do is cut of the plastic sleving one inch from each side you are working with take the copper wires that is what they should be spread them apart overlay them and then twist till it gets really fine and then wrap it up with Electrical tape and it should be just as good as before in therey.
