RE: Where to start
My props swing 4" - 8" from the transom forward...depending on which boat I'm doing. For a .40 try to stay around 4 - 4.5 lbs. Try to stay with a 3-5 lbs per hp/weight ratio....depending on what .40 you use. (a bearing or bushing motor)
Here is some pics for you.
