RCU Forums - View Single Post - post some pictures of your pattern plane!!
Old 01-06-2006 | 10:05 PM
  #238
Zeneith
Default RE: post some pictures of your pattern plane!!
ORIGINAL: Dominique ACM
hello Zeneith,
Could you please give us more informations about this Model (Beam) ?
DG
Hi Dominique ACM,
Here are the specifications of the Mega Model's Beam as per the manufacturer information
Fusalage Length: 1990 mm.
Wing Span: 1883 mm.
Wing Area 62.5 Sq. Dm.
Engine 1.40-1.60
Weight: 4.5-4.8 Kg.
My Beam installed
Motor : HACKER C50 14 XL Gear 6.7 :1
Batt : Li poly 5S4p x 2 packs = 37 Volts.
Weight: 5 Kg (Inc. Batt)
They have 2 versions F-3A and 3D, here are some pics of their 3D version...It is pretty cool airplane!!
ID:	382409   Click image for larger version
ID:	382410   Click image for larger version
ID:	382411   Click image for larger version
