RCU Forums - View Single Post - Fixing problem planes on G3???
Old 01-07-2006 | 02:57 PM
50%plane's Avatar
50%plane
Default RE: Fixing problem planes on G3???
First of all I have downloaded a model that was supposed to fly very similar to a Mini Funtana. Well it will not knife edge at all. It falls out of the sky in a knife edge no matter how much rudder I add to it. It also trys to roll out of a kife edge terribly, Hover is next to impossible.
What's wrong with that one? I've flown the F40 and that's the way it flew.
I one day hope that Rick and (forget his name) start sharing their great models and paints with the rest of us.
You might want to check on the veracity of that statement.
Also another problem I have is getting some of my models to pull the tail around when I go inverted and push it hard over the nose into an inverted flat spin etc. I have tried moving the CG around to get them to work and I can get it close but then it effects the ability to hover etc.
Why don't you start with the default settings. If that doesn't work, try improving pilot skill.
Woops
