5900 series and Futaba pcm
I have two new 5945's that have the 1.04 version sticker on them. When connected to a Y they do not work correct (shutter or quit). I do have some that are marked 5.10 (mfg date I would think) and they seems to work fine when used with a Y. I thought the only servo's you had a problem with was the 5955's when using Futaba PCM. I will be sending in the 1.04's but how do you know if a 59 series servo is updated or not? If it has a date type sticker (IE 5.10) does that mean they are updated? I have been told the 1.04's work fine with Hitec PCM but I would think you sell more servo's to Fataba users then people using Hitec PCM equipment.
