Captinjohn,
I suppose you refer to the model Extreme 330 from my AFPD-page, dated 25.12.2004.
If you left click to the expression 'download here' you'll get a menu:
Open rExtreme.zip
-Open with Winzip
-Save to disk
Select save to disk, then select your directory to store it.
Since this is a rather old model, it does not come in a self installing EXE, you have to manually install the model:
Open the Windows explorer, navigate to the aircraft folder of AFPD, eg.
c:\program files\ipacs\aerofly professional deluxe\aircraft
Create a new folder with the name \rExtreme
You must use this name and the small and capital characters!
Double click to the rExtreme.zip to open it.
Then drag all files into the new folder.
You should end up with a directory like this:
c:\program files\ipacs\aerofly professional deluxe\aircraft\rExtreme
And it contains several files:
_readme.txt
preview-rExtreme.txt
rExtreme.tgo
rExtreme.tmd
rExtreme.tmg
Regards
Karl-Heinz (Rodeo)
www.rodeo.onlinehome.de
