RCU Forums - View Single Post - Revive Enya 35 model 5224?
Old 01-09-2006 | 12:27 PM
NM2K
My Feedback: (14)
Default RE: Revive Enya 35 model 5224?
ORIGINAL: Weasel Keeper
I recently came into possession of a box of old engines mostly CL. There are a couple of little cox engines a McCoy red head, an Enya 35, and another engine whos name escapes me right now. Soaked them in alcohol and every one of them now turns freely. The Enya is the most interesting one to me for RC use. The thing has great compression. It has a square carb with a throttle barrel so I guess that means it is an RC version. I'm not really sure. Anyway the needle fitting is broken. Does anyone have any idea where I might find parts for this carb? Any advise or insight would be most appreciated.
Someone posted Carol's number at Altech Marketing a while back. Maybe they will repost it for you, or you can do a search on this forum to find it. She will be able to help you, most assuredly. Enya's are fine engines and usually provide good performance for many decades. It sounds like you lucked out. The other engines that you mentioned also have a following in control line circles, although they do not fetch much money on the used market.
