Help with a ASP 80 4 stroke!
Allright guys ive read and read and read and found nothing! or else im just too tired to read any more... [:'(]
anyways i was given an asp 80 (old school) 4 stroker engine. the problem being is it wont run now, ive seen it run but not recently. last time i saw it run it sounded allright but when it was given to me it was fiddled with. So my questions are...
1. what were the low end/high end needle factory setting for the asp 80 (or magnum as i've read that they say are the same)?
2. when the valves are adjusted does it matter wich stroke the engine is on? or as long as that the piston is in TDC???
3. can i get a rebuild kit and where? for wich model engine? magnum .91???
where should i set the needle for starters??? im using Omega 15% fuel i've gone through 2 cycles of glow driver and no luck starting this bad boy!? imy patience is getting thin [>:] help!
thanks-Raf
