RE: Moki 180/Glow engine
You cant guarante the ring is not gumed up without taking the piston out. You can guage the compression it has. it shoud be quite hard to flick over the compression. it will still runn even if the ring is gummed but you will get similar symptoms to a lean run. ie quits after running for a while and it will get hot
