RCU Forums - View Single Post - Moki 180/Glow engine
Old 01-11-2006 | 08:53 AM
  #33
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: Moki 180/Glow engine
2-3 turns depending on your setup. What muffler is it? If it's a pitts try blocking one of the stacks. You may have a fuel draw issue. If it's a fuel draw issue it won't richen up, that could be your problem. Do you have a pump or regulator? Or just use muffler pressure? How far is the tank from the engine? How high is the top of the tank with respect to the carb fuel inlet?
ORIGINAL: cpalmerwf
Do you know how many turns out from closed one should start with?
