Plan Protector ??????
RC Builders,
Can you use 3M 77 adhesive spray on the plan protector? I like to build on a hard, flat kitchen counter top ( not the wife's) that does not allow use of pins. I therefore use the 77 spray on top of the plans and ahere wax paper that also receives the 77 spray to adhere the balsa. This technique is usually reserved for the fuse and works well. I'm just wondering if the plan protector would work in place of the wax paper, as I have read that very little sticks to it. Has anyone tried this?
ED
