RCU Forums - View Single Post - Help with a ASP 80 4 stroke!
Old 01-11-2006 | 04:22 PM
JPal101
My Feedback: (32)
Default RE: Help with a ASP 80 4 stroke!
As I said before, Pull the tank and do the water test, also remember to replace all your fuel lines including the pressure line from the muffler. Then reinstall and fill it with fuel, open your needle valve to recommended amount of turns, hold your finger over the exhaust opening in the muffler then crank the engine with your starter without the glow starter. You should see fuel going into the carb. When you do connect your glo igniter and fire it up
