RCU Forums - View Single Post - stock mufflers
Old 01-12-2006 | 11:06 AM
av8tor1977's Avatar
av8tor1977
Default RE: stock mufflers
Hi,
A baffle is a device inside the muffler to help cut down noise. What you want to do is completely "gut" the muffler. Open it up and take out anything and everything in there except for the two pieces of tubing that the bolts go through. These keep the muffler from collapsing when you tighten the bolts. Then put it back together, drill two holes for your outlet tubes, and braze or silver solder the outlet tubes in. Here's a couple of pics. The last one is a custom muffler I built for my Katana.
Good luck,
AV8TOR
ID:	386155   Click image for larger version
ID:	386156   Click image for larger version
