RE: Throttle Linkage Woes
Throw the plastic arm away and make one out of aluminum. Get rid of the ball on the carb arm. Put a z bend in it and bend it to get it to line up with the aluminum arm you make. Use ez end with a set screw on the aluminum arm. Use the ball and socket on the throttle wire from the servo for isolation.
