RCU Forums - View Single Post - Genesis suspension Q's
Old 01-13-2006 | 12:46 PM
JPKII
Default RE: Genesis suspension Q's
That is one of a few items I found that were omitted from the manual. Another being the 4mm lock nut that holds the external shift unit on the main shaft. That nut was replaced with a stub shaft that rides in bearing and bearing support that is mounted to the frame of the truck.
