RCU Forums - View Single Post - RTF, not really ready to fly... A newbies chronicle
Old 01-13-2006 | 09:27 PM
calebep
Default RE: RTF, not really ready to fly... A newbies chronicle
I do have a battery charger, I use my motorcycle trickle charger... I also have extra banana clips, a glow plug wrench, assorted screw drivers and allen wrenches. As well as a couple of fuel filters. I have plenty of fuel line too. I used a tap and die set for my prop reamer, it worked good for me. But I will probably end up getting one of those too.
The question I had about the wrench for the prop. I was thinking there might be an open end wrench one much like you use to change dremel tips. You know, to hold the shaft from turning while you are tightening the end. Or do you use an adjustable or a regular open end wrench?
Another question that just came up, my fuel tank is pretty much stuck in the fuselage, but it is not secure. It will rattle around in there. Any suggestions on how to keep it from doing that?
Caleb
