Hitec HS-5955TG Servo Installed on Genesis
I just finished the install of this servo. Steering response is much faster than stock. Here are the specs of the servo: 24 Kg.cm (333 oz.in), 0.15 sec/60 all at 6.0 V.
I'll run the truck tomorrow and see if it helped the torque steer or the truck running wide in the corners.
I do have a question for all the people that have installed higher torque servos. What did you set the servo saver to? Right now I have mine set to 8.0 mm from the plate. Any advice?
Joe
