Best glue for big scale
Hi foxx,don't think it is as strong as epoxy,it is water proof,does expand as it drys ,helps to mist one part being glued with water,I use it mostly on wood to foam, if parts aren't clamped together the expansion of the glue as it dries will seperate the parts,sands easy,the fumes can get your lungs.
