glue
I totally agree with Rodney about the titebond.Titebond will build a stronger plane than anything else.Like someone else stated,and I also use ca to tack parts in place but the titebond is the stronger of the two including epoxy in my experience.You can glue any type of wood with titebond and the glue joint will be stronger than the wood itself.But you will still need epoxy in certain areas as you will learn,such as sealing the engine area by thinning the epoxy with alcohol.Hope this info helps,my 2 cents.
