ORIGINAL: Dauntae
There is no holding it on there, It is a new threaded pipe with a section for the nipple, I'm going to make one for a saito 100 If I have time I'll try to make a few but I work in a manual section and takes a little time to make, The CNC guys could pump them out but could never get them to set it up for a personal project. They will be stainless steel because that's all we use at my job. Should have a few dome this week working through luches.
Dauntae
The same effect could be achieved tapping the original exhaust port. The adapter you are interested in is a bit thicker, but that isn't necessary with a 4 stroke. They produce more than enough heat to vaporize the smoke oil. You only need to be creative if trying to smoke a 2 stroke. 4 strokes have 2 ignitions per every revolution. 2 strokes only have one ignition per revolution. 2 ignitions = twice the heat. That is why you don't need anything special to get good results. If you really feel gung ho, IMHO there are 2 ways to improve the amount of smoke produced: 1. Heat the oil closer to its flash point (240F) before it enters the muffler 2. Make the muffler hotter to vaporize more of the oil as it enters. Try tapping the original exhaust port first and check the results before going all out. Minn's article tells you exactly how to do it. With 4 strokes, smoke is a piece of cake.
Mods
