RCU Forums - View Single Post - UCanDo3D (.46) Landing Gear
Old 01-15-2006 | 11:54 AM
Sturtz's Avatar
Sturtz
My Feedback: (20)
Default RE: UCanDo3D (.46) Landing Gear
First ditch the stock alum gear. Go to [link=http://www.graphtechrc.com/]Graphtech[/link] or maybe here [link=http://tntlandinggear.com/store/shop/composite_landing_gear.htm]Carbon gear[/link]
Order up a UCD.46 replacement CF gear. Much lighter and will flex better.
Remove the gear and everything near the gear block area including the blind nuts. Soak it in thin CA let cure. Take some tri-stock and lay on either side of the gear block for support. Finally take some flibercloth and 30 minute epoxy glassing the whole area.
Go to bed. Next day drill two holes where the old ones were fitting them for 1/4" bolts and blind nuts. I personally use nylon bolts on most of my planes but some folks hate them and prefer to rip the bottom out of their planes rather than simply bring a handfull of spare nylon bolts to the field. If they shear off on a hard landing no big deal. Just grab a couple more and maybe replace a broken prop. And if they shear off deeper inside the blind nut just take a small flat head screw driver and heat it up on the tip. Let the blade melt into the sheared off bolt and hold it there till it cools a bit. Then simply screw it out and replace it. I always keep one of those $5.00 butane mini torches in my tool box for just that reason.
Also adding a nylon washer with the nylon bolt seems to help as well. Good luck.
Sorry,,, didn't have a pic handy of my UCD/46.
