Kyosho G-Trick Durability?
I can't speak for the g-trick, but I have had problems in the past with kyosho arfs busting glue joints. On my Pitts S2C, after the second flight the firewall separated and the only thing holding the firewal/engine on was the cowl. Still landed it safely, but it still shouldn't have happened. I emailed Kyosho and aparently they went through a period where they had a bad batch of glue. Kinda makes you wonder huh!!! I personally will NOT own another Kyosho plane again. Lost my pitts and my cap 232, but that's a totaly different story......
if you are wanting an aerobatic plane similar to the g-trick, look into the u-can-do 3D from great planes. Here are the specs for both.
Kyosho G-Trick
Wingspan: 66.1" (1680mm)
Wing Area: 810 sq in (52.25dm)
Weight: 8.2-8.4 lb (3700-3800g)
Length: 65.4" (1660mm)
Wing Loading: 23.4 - 24 oz/sq ft
Airfoil: Fully Symmetrical, Mid Wing
Engine: .90-.91 (2-stroke) or .90-.91 (4-stroke)
Tuned pipe
Price: 467.49 (tower hobbies)
Great Planes U-CAN-DO-3D
Wingspan: 65" (1651mm)
Wing Area: 1024 sq in (66.1 sq dm)
Weight: 7.75 lb (3.5 kg)
Wing Loading: 16-17 oz/sq ft (49-52 g/sq dm)
Length: 68" (1725mm)
Airfoil: Fully-symmetrical mid-wing
Engine: .61 -.91 (10-15cc) (2-stroke)
OR .70 -.91 (11.5-15cc)(4-stroke
Price: 189.99 (Tower Hobbies)
Pretty similar. But the Kyosho cost over 2 times more that the GP. Plus the GP ARFs are built allot better that the Kyosho. This is just my $.02. But I know which one I would get!! I hope this helps ya out!! :thumbup:
