i just glued everything back with 30 min epoxy(the hot glue they use is crap for landing gear) then used some 8-32 allthread and drilled from the wing mount bulkhead into the gear block all the way into the air ramp, soak the allthread in 30 min epoxy then screw the allthread (preecut to length with screwdriver slot cut in it)all the way through, mine never came apart again
