ORIGINAL: Mods-R-Me
I am always willing to improve my knowledge. Since you seem to be an expert in this area, why is it that 4 strokes always produce better smoke than 2 strokes? I've even placed temperature gages on both and verified that 4 stroke exhaust is hotter than 2 stoke exhaust. Have I missed something in my analysis? I've seen this many times and up until now I thought I knew why.
Mods
ยด
Expert.. no.. its just a well known fact
What part of this is it that you dont understand?
ORIGINAL: Blue_Moon_
two stroker: the fuel ignites evry time the piston is at the top of the cylinder.
four stroker: the fuel ignites every other time the piston is at the top of the cylinder...
> Therefor, The two stroker produces much more heat then ar normal four stroker.
edit: i also want to add that the four cycle produces more heat made from friction then a two stroker. but this heat is very small part of the total heat. the overall heat production is much bigger on a two stroker
