RCU Forums - View Single Post - saito .91 smoke????
Old 01-15-2006 | 07:16 PM
  #47
Blue_Moon_'s Avatar
Blue_Moon_
Default RE: saito .91 smoke????
ORIGINAL: Mods-R-Me
Expert.. no.. its just a well known fact
What part of this is it that you dont understand?
ORIGINAL: Blue_Moon_
two stroker: the fuel ignites evry time the piston is at the top of the cylinder.
four stroker: the fuel ignites every other time the piston is at the top of the cylinder...
> Therefor, The two stroker produces much more heat then ar normal four stroker.
edit: i also want to add that the four cycle produces more heat made from friction then a two stroker. but this heat is very small part of the total heat. the overall heat production is much bigger on a two stroker
Oh, I understood all that was said and it was very well explained. Thanks for correcting me on the ignition cycles of both engines, but I didn't see an answer to my question. I would like to know the facts [sm=wink.gif] on why 4 strokes product better smoke than 2 strokes if this is not heat related. I'm not the smartest guy in the world so I need a little bit of elaboration on the subject.
Mods
[/quote]
Rply blu_moon
Ohh i see... im sorry to say that i dont have that much experience of smoking systems. Perhaps someone else can try to figure out why 4-c produce better smoke then the warmer 2-cycle. Thats a good queestion!
