RE: Stupid build question
Something else to consider later on. I usually check my CG before I mount the receiver. Then I place it where it will help. Since the battery is much heavier, I save that for nearly last to use as weight to bring the CG in. I may mount the battery in the nose or behind the CG--wherever its needed before adding extra weight
