IR Terminal Prices
Hi Jake
Sorry for the delay, I've been a bit busy the last week and a half. The prices are as follows:
IR Handheld Terminal: Includes terminal, one onboard IR transceiver, connection cable and instructions.
$245
IR Transceiver: If you have more than one aircraft with a SimJet turbine.
$75 (was$110)
Y-Harness: Y-harness to replace existing Cockpit display harness(required for IR Handheld)
$45
IR Handheld/Y-Harness Combo
$275
There will be an upgrade pack available that is to include a download cable, software and the handheld. It's target price is around $295. I haven't received one yet, so I can't comment more on it till I try it out.
I will work out a complete conversion pack once I try out the conversion software. In the meantime, you can send your ECU into us and we'll upgrade it for the price of return shipping.
The New ECU software retains the same "awesome" spool up time and will retain or give you a little added boost in the thrust department.
If you have any other questions, please do not hesitate to ask.
Ed
