RE: Old balsa kit CA glue will not bond
I agree. Ca sets, not drys, based on the trace moisture in the material being glued. Spraying the balsa with water will not be the same as allowing the material to draw moisture slowly. That's why I suggested using kicker. Ca kicker causes the glue to set without trace moisture being in the wood.
