ORIGINAL: jolupach
I forgot about the charge time. First, i thought that i was going to charge a pair of IB3800 in 30 minutes with the 977, but is taking me about 40 minutes because the packs are getting about 4350 mah instead of 3800 mah, great packs!
What setting are you using? I've got a Pulsar Sport and even thought it's rated at 8 cells max - you have the problem of using say an external 15A power supply not giving the full 15A as more cells are charging - like 7 cells will have it imput at about 13.5 - 14A. So if I try say 8 cells that are getting upwards of 1.5 - 1.75Amps per cell it brings down the charging amps say from 5A down to 4 amps - does the brain977 do that also?
