Kits for the AMA Cub/Delta dart are available at most hobby shops, or you can order them from Sig. They cost about two bucks and come with a very clear set of plans and directions. My fourth graders have no problem with them, so a high schooler should be about to whip through the construction in about 10 minutes.
While you are at the hobby shop, pick up a few extra sticks of wood and build one of these
http://www.charlesriverrc.org/articl...ymichaelis.htm
You will learn more from a whipper whiz than from a delta dart.
