RCU Forums - View Single Post - saito .91 smoke????
Old 01-16-2006 | 09:56 PM
  #70
Lowlevlflyer
Default RE: saito .91 smoke????
That's right, you HAVENT talked about exhaust temps, and exhaust temp is what matters in the production of smoke... not the overall temp. It doesnt make a hill of beans difference what the temp is in the combustion chamber.
ORIGINAL: Blue_Moon_
ORIGINAL: britbrat
Ye ye ye, perhaps the four strokers does produce better smoke but the 2stroke ENGINE gets hotter then a normal 4c. its just stupid to consider something else
Blue Moon -- you are truly all alone in this.
Combustion temps are related to a bunch of things, which include compression ratio, ignition timing, induction timing, exhaust timing, squish area, combustion cycle, fuel, air-fuel ratio, load & heat rejection. There is too much variability in conditions for a sweeping statement to have any validity.
What is relevant to the question asked is the sustained temperature in the exhaust system, & 4-strokes generally have notably higher sustained exhaust temps.
If you doubt it -- grab the exhaust header of each type (be sure to chose engines making similar power) & let us know how it goes. Many of us can tell you from first hand experience [], but you do your own thing.
I meant that the whole engine (overall temp) is higher then on a 4c. I have never talked about exhaust temps ;-)
