RE: Old balsa kit CA glue will not bond
If too much kicker is used you will see an immediate reaction in distortion, heat, and even smoke at times. I use a spray nozzle that puts out as fine an atomization as possible and hold it back from the work about a foot and try and spray just enough to let a couple of droplets fall on the glue joint. That's usualy all it takes to start the curing.
