RE: saito .91 smoke????
Mike, Yup that's exactly what I was thinking, closer to the head the better, & longer travel time to the mufller= more smoke?
Mine will be even easier to do. The saito pipe is smooth, only threaded at each end with a jam-nut on it so I can tap it just clear of the jam-nut putting the nipple within a 1/4 inch of the head, this should produce good heat.
My son in-law works at Kragens & gets 25% off, so I'll see if they have that little pump you turned me onto, if they don't I'll go ahead & order it from JC. Thanks Mike
Mark
