RE: Help with Aileron Repair
i agree with blwblw i never use ca hinges i always use pinned hinges the ones where the pin is captured in the hinge not the ones where the pin is bent and you have to stick the bent part in the slot. i've repaired ailerons by pulling on the hinge and applying a bit of heat out it comes
good luck
