RCU Forums - View Single Post - Seniorita?
Thread: Seniorita?
Old 01-18-2006 | 11:27 AM
mnrcaerobat
My Feedback: (197)
Default RE: Seniorita?
Did you look at the Kadet LT-25? It has the ailerons and is a taildragger.
I would add a full strip aileron like the LT series. I am not sure about flaps. Some have built this plane with no dihedral. To make it a taildragger, I would move the main landing gear to the front leading edge of the wing and add a tailwheel. You will probably have to make a hole in the elevator if you use a wire type tailwheel setup.
